red31
Jun 19, 2019Explorer
Damdifino wrote:
Voltage at the controller is 18.63 (or -18.63 depending on which probe on the micrometer.)
you could share which probe you are using for the + and which one for the - to confirm polarity, if the probes are in the correct spot on the voltmeter then red is + and black is - so if you probe the PV+ terminal with the red and the PV- with the black you should get a positive reading, if you reverse the probes you would get a negative reading.
Same with the battery controller screw terminals Same with the battery itself. And the battery measurement is ?
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
