Chris_Bryant
May 26, 2013Explorer II
Even though I am apparently not qualified, check for 12 volts at the Y terminal at the circuit board. If you have it, bypass the freeze sensor (just short across the terminals). Bad freeze sensor is the most common problem for this.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Mar 27, 2025
