144Grayling's avatar
144Grayling
Explorer II
Mar 22, 2022
No power to gas water heater switch
I have a 2008 Komfort TT with an LP only water heater with automatic spark ignition. It was working just fine, then all of a sudden it would not light. Only cold water from the tap. There is gas, but no voltage at the on switch. We are on shore power. Other 12 volt things work (lights, range hood) but not the water heater. There is no fuse in the control center labeled ‘water heater.’ Any help for hunting down the problem would be appreciated.
Thanks!
  • When my water heater lost power at the switch it turned out to be the T-stat had given up. Killing all power to the water heater and switch.
