westend
May 09, 2014Explorer
rjldar wrote:Measure across battery terminals for acceptable 13+ VDC when converter is powered. You might check to see if you have a manual resettable circuit breaker on a battery wire that connects to the converter.
After posting, I went back out to start testing for correct amperage and voltage. found out the batteries are completely dead. It has been plugged in for two weeks now. with the cover off the fuse panel, I realized the converter wasn't making any noise. If I get real close, I hear a high pitch wine. I'm thinking I have a bad converter. Any thoughts?
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
