SUMRX4's avatar
SUMRX4
No power to inverter
Need some quick advice please. Set up yesterday and everything was fine. Woke up this am to the Co detector chirping. Realized I didn’t have any lights. Looked around and unit is dead. I have power at the pole confirmed by my power watchdog. My inverter is not on. Will not turn on. Nothing on the screen. Xantrex freedom x inverter in a 2021 KZ Durango Gold. Battery switch is on and relay to battery is not tripped. Have 4 days ahead on me here and 4hrs from home. Help! ????
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    One thing I will warn you about.. on the inverter.. if it's like Mine. like inverter the wire leads all (Both 12 and 120 volt) connect in apanel in what I call the REAR (opposite the fan)... and there is a fuse.
  • If you have a voltage meter always check the power with that. By just looking, you don't know if it is the plug, fuse, ground or loose wire. I had a problem with mine a while ago, so I down loaded the trouble shooter document for it and found that it was working fine. The problem was elsewhere. If you don't have VOM then learn how to use one and get a good one. Good luck!
  • Might be a good idea to load check the batteries as they should have lasted the night if initially charged.
  • Nevermind I’m still sleep apparently. The breaker for the converter was tripped in my panel box. All seems fine now.
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 10, 2026
