tenbear
Sep 08, 2016Explorer
Use your multimeter to check for voltage at the 12v input to your fuse panel. If no voltage there, follow the 12v wire that comes into the fuse panel and check for 12v again, keep doing this until you find 12 volts.
You should probably check for 12v from the battery positive to ground to check the ground.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
