westend
Oct 12, 2016Explorer
It seems like someone did point you towards the breakers.
The actuality of RV 12V is that it needs periodic maintenance, as you found out. Good luck going forward and I'd suggest you invest in some anti-corrosion spray or grease.
bikendan wrote:
probably tripped the resettable circuit breaker that's tucked in along the A-frame.
look for a little silver/gray block that has a tiny black button.
push it to reset it.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
