RJsfishin
Aug 23, 2015Explorer
KD4UPL wrote:
A short would trip the breaker at the source. I think you should be looking for an open circuit.
Do you have a transfer switch somewhere for a generator?
Do you have a compartment set up for a generator? You may have to plug another cord into an outlet to pass the power on inside the RV. Some are set up like this for a generator to avoid the cost of a transfer switch.
Do you have an inverter installed with a built in transfer switch that may be malfunctioning?
Did you read this post ??????????????????????????????????????
Does the generator supply power ??????????????//
Do you know how everything operates ?
How long have you had this trailer ?
Like pullin teeth !
