dirt_dawg
Aug 24, 2015Explorer
open your power plug and check the wiring. I had same type of problem. Spent days checking power boards. traced back to plug. the wires will work loose inside of plug after time from twisting and use. I reconnected with heavy duty lugs. This also cured my phamtom GFI failures.
