bstumpExplorerJan 22, 2017No shore powerPower was off at csmpground for couple days. Came back on but i still have no power in the 5th wheel when plugged in. None of the breakers were tripped and there is power to the outside box. Power is ...Show More
Old-BiscuitExplorer IIIJan 22, 2017You stated " Power is fine on the generator but no power when plugged in to shore"Transfer switch 'stuck' on generator side and NOT swapping back to shore power side when
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 11, 2026
Related ContentShore power questionGenerator/Shore Power Work, Battery Power Doesn'tDC power vs shore powerShore power plug conversion?Ok to run shore power without battery?
