Power was off at csmpground for couple days. Came back on but i still have no power in the 5th wheel when plugged in. None of the breakers were tripped and there is power to the outside box. Power is ...
Did you check for power at the incoming breaker or lugs ? If there is none there and you have power at the power pedestal, then you must have a break some place in your power cord or plugs.
Also if your breaker at the power pedestal was tripped, before you can reset it, you have to switch it off.
jack L
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
