Power was off at csmpground for couple days. Came back on but i still have no power in the 5th wheel when plugged in. None of the breakers were tripped and there is power to the outside box. Power is ...
There should be two sets of terminals in the box. One side shore power and the other is power from the generator. If you are comfortable width dealing with electricity, and have a tester, you can check the outgoing lugs when plugged into shore power and when the generator is running. You will probably have current with the generator running and not when it's not running but plugged into shore power. If this is the case the XFR switch is bad.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
