flip418ExplorerSep 25, 2021No Shore power2015 Keystone Cougar 330RBK that will not power up with just shore power. I assume the inverter but I’m unable to locate! Help!!
BB_TXNomadSep 25, 2021You need to verify power is actually getting to the trailer. The pedestal, your power cord, your internal breaker, etc. Voltmeter is a necessity.Does anything 120 vac work inside the trailer?Do you have generator prep with a transfer switch? Those transfer switches are a known problem.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
Related ContentShore power questionGenerator/Shore Power Work, Battery Power Doesn'tDC power vs shore powerShore power plug conversion?Ok to run shore power without battery?
