If you remove the access panel in the storage compartment on the side facing the hot water heater, you will see it mounted to the floor. Mine is just past the vacuum canister installed in mine
The above was copied from the keystone forum
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
