Golden_HVAC
May 30, 2013Explorer
wkswenson wrote:
Clicky
Just be careful as these require a full depth electrical box and many RVs have shallow boxes. But great technology.
The reason I would keep using the cube adapters is that they use power even with nothing plugged into them. So the recommendation is to unplug the "Cubes" or also known as "Wall Warts" so that they do not continue to use power while the device is not in use.
Did you know that even GFI recepticals use power while nothing is plugged into them? It is only a few watts per hour, per GFI, but still a GFI consumes power, and might cause a solar powered home to require installing extra panels due ot the wattage used by the wall warts and GFI recepticals.
Fred.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
