enblethen
Nov 04, 2013Nomad
How do you fill the fresh water tank? Do you have a valve that says "fill" tank? If you have such a valve it could be in the wrong position. If your fresh water tanks fills by gravity fill only this is not your problem.
Check between the pump and the fresh water tank for water. Disconnect line from tank at pump and see how much water you get. Does your pump have a screen filter on the tank side? is it clean/
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
