pkunk
Nov 04, 2013Explorer
On your Mirada, the water control panel in the rear compartment can be a bit confusing. If you stare at the pictogram long enough it will be evident. The valve orientation for 'use' has only one valve open. It is just the opposite from 'fill'. Every thing else should be closed which on that panel is vertical on the oval knobs. If you don't solve it, PM me and I'll take a pic for you.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
