Chargerzuk
Nov 05, 2013Explorer
I am going to try it with the fill valve closed like Pkunk suggested. I don't think there is any line blockage because when I hook it up to city water I have good flow and then if I turn on the pump for a minute it increases the flow. If the valve doesn't work I am going to attach a hose to the pump to see if it is pumping with good pressure and if it doesn't work at the pump then the line must be blocked or a valve closed.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
