- dieselgrinExplorer
Joe417 wrote:
If you are mechanically and electrically handy, yes you can, depending on the AC you have.
My AC fan started making a lot of noise and stopped turning. Pulled the motor out and found the bronze bushings were riveted in. I carefully remove the armature from each half of the motor housing and found they weren't worn out just dry of grease. I drilled the rivets out, polished the shafts, heat greased the bushings, and reassembled with screws.
Still running well after maybe a year and a half.
If the bushings are worn you may not be able to find replacements.
You can always replace the fan motor. Most are sold on ebay.
Probably more than I can handle. Lol. I'll climb up there to check brand and model. It's pretty old. - Joe417ExplorerIf you are mechanically and electrically handy, yes you can, depending on the AC you have.
You can always replace the fan motor. Most are sold on ebay. - dieselgrinExplorerMy bust. It's roof unit. It's ducted and has simple cover for shower .
- bikendanExplorer
dieselgrin wrote:
Is there a way to grease the a/c fan? If not, what about replacing? Thanks
Is it ducted a/couple or blast from the center a/c? - gatorcqExplorerNo, there is no zerk fitting. replace it. Most fans are less the $100.
Of course I am guessing as to which A/C fan you are talking about. Dash, basement, or roof.
As you did not provide enough information.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 23, 2026
