joebedford's avatar
joebedford
Nomad III
Jan 02, 2016
Noisy banging range hood exterior vent flap fix??
I'm in the RGV so wind is a daily issue. The flap bangs and the noise disturbs us.
My previous RV had an exterior flap that I could latch closed from inside the RV. This RV has a plastic flap with two little tabs to hold it closed. They are effective but even though I'm tall I can't reach them without 2 steps of a ladder against the outside of the rig. It's a pain to constantly close and open it.
I've been thinking of putting a weight on the flap to dampen its movement or maybe weatherstrip to stop had plastic banging on hard plastic.
Anybody have this problem and come up with a solution? No, earplugs don't help.
BTW, this vent is also for the microwave which is over the range so there is no easy access to it from inside.
  • Chris Bryant wrote:
    I use a washer and magnet.
    So you glued the washer to one side, and the magnet to the other? This sounds like a nice permanent solution. I assume that the fan over powers the magnet?
    LynnandCarol wrote:
    we use the awning assist pole to latch the vent. we also use the hooked end to clean out the gutters!
    Good stuff right there!
    It occurs to me that you could wedge a rubber ball or something similar in there too. The awning wand could come in handy for that too.
  • 2oldman wrote:
    Plastic shopping bag stuffed in from outside.
    This, or a rag. Just don't forget you left it in there.
  • Joe, we have not had a problem with wind, except one time, when the vent opening was pointed right into the wind. We put a piece of plastic temporarily over the inside of the vent hood -- problem solved.
  • profdant139 wrote:
    We took ours off completely. Instead of a flap, I installed window screen material inside the opening to keep the bugs out.
    Too much wind would come in.
  • We took ours off completely. Instead of a flap, I installed window screen material inside the opening to keep the bugs out.
  • I like the suggestion using 1/4 turn latches, but like I said, I don't have access from inside:
  • we use the awning assist pole to latch the vent. we also use the hooked end to clean out the gutters!
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
