2manytoyz
May 04, 2019Explorer II
Noisy Dometic RV A/C 60 Second Fix
After a recent trip, one of our Dometic roof top A/C units started making a loud/unusual buzzing noise.
I pulled the cover while it was running, and discovered one of the hard lines from the compressor was rattling.
I did a quick and dirty fix, one suitable for a DIY at a campground. Only required removal of 4 screws, and shoving in a piece of pipe foam. I put a video online here: https://www.youtube.com/watch?v=5X5BMY1c7tk
I believe the padding on the nearby clamp is shot, so it's not holding the copper tube tightly anymore. The unit is a 2015 vintage.
I noticed how rusty the shroud screws were, and ordered some replacement stainless steel screws. When I go back on the roof to replace the hardware, I'll see about removing the clamp, and maybe wrapping the line with silicone tape, then re-installing the clamp. Shouldn't need the foam after that.
File this tip under "I'll keep that fix in mind if it occurs during a trip".
I'll post an update with a more permanent solution soon.
Happy trails...
Happy trails...
