KATOOM's avatar
KATOOM
Noisy furnace motor
Haven't owned my trailer during the winter. So I turned on my furnace for the first time ever and the motor has a light whizzing/squealing noise to it. Not completely constant as in one pitch but it is a constant noise. I cant tell if its a bearing noise from lack of usage or that the squirrel cage is barely touching something or its just normal. Are those furnace motors hard to remove or mess with? I overheard someone telling someone else that its not worth dealing with them and just to replace the entire unit. Obviously not the choice I'd choose unless there was no other option.
  • Letting it run for awhile sounds worthy of trying. I'll see if that helps.
  • Old-Biscuit wrote:
    Really depends on Mfg. and model.
    Motor bearings are sealed..so oiling them won't help.
    Year/Brand/Model info would be helpful.
    The blower motors have oil soaked bushings, not sealed bearings, easily and effectively oiled. As mentioned, either sewing machine oil or 20W non detergent motor oil will fit the bill.
    WDP
  • I hadn't used my heater in a couple years and when I finally turned it on during one of my "inspections" it squealed. I turned the propane off and let the fan run for an hour and it hasn't squealed again - might work in your case and didn't cost a dime.
  • RoyB's avatar
    RoyB
    Explorer II
    I hope you are not confusing the loud noise the blower usually makes with a possible bad bearing noise.
    My furnace blower sound like it sounds when you are sitting in the back roll of seats on a MD80 Jet Plane... a real loud GRRRRRRRRR type noise.
    The loud noise coupled with the 6-8AMPS the blower motor draws sure does keep me from using the gas furnace very much.
    Roy Ken
  • sum1 wrote:
    Yours may be different, but I have gotten YEARS of extended and quiet life out of squealing fan motors by getting a couple of drops of oil into the bearings. Get creative to reach the bearings: sewing machine oil dispenser, Q-tip taped to a length of wire, a piece of broom straw dipped into the oil, a twig with just the right curves, ...
    Because the bearings are sealed, that wont work unless you get the motor out and drill small oil holes into them. For that much trouble, you might just as well replace the motor. JMO
  • Yours may be different, but I have gotten YEARS of extended and quiet life out of squealing fan motors by getting a couple of drops of oil into the bearings. Get creative to reach the bearings: sewing machine oil dispenser, Q-tip taped to a length of wire, a piece of broom straw dipped into the oil, a twig with just the right curves, ...
  • I had to replace mine right after hunting season this year. depends on the model, that will tell you the cost of the motor. there are somethings I can do on my TT, furnace is not one of them
  • Really depends on Mfg. and model.
    Some are easier than others to get to motor and fans
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
