MrWizard
May 23, 2016Moderator
thats a totally enclosed unit
in the bottom of that picture, it looks like rubber mounts for the motor
it is possible they are too tight
you could put in a new piece of flooring, say a piece of 5/8 plywood with a hole cut for the exhaust, maybe some metal flashing/heat insulation
an set the whole genset enclosure on new mounts
look up the mounting instructions for that model
should be easy to find the PDF file, should also be in your generator manual that came with the install
Cummins Onan QG manual
from the pictures, it looks like internal springs between the power section and the enclosure floor
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
