Chum_lee
May 23, 2016Explorer
N-Trouble: The hole in your compartment door is for combustion/cooling air and you can't block that off. If you do, you risk damaging the genny from overheating it. (warranty void!) If the compartment is otherwise sealed well you may not get enough combustion air either. That's why most genny installations inhale and exhale out the bottom or the side if mounted in the rear basement compartments!
Chum lee
Chum lee
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
