Jim-Linda
Jan 15, 2014Explorer II
First, measure the hole where you current fridge is, go outside, remove the grill behind the fridge and measure side-side. Now measure front to back. Go inside and measure top-bottom, realizing that some of what you see is trim.
Now measure the doorway opening, should be somewhere between >24in and ,28in. Now go to Lowe's or HP website and search for a unit within your measurements. You need one of the measurements to fit within your door size, probably front to back.
When you find one, they will deliver it, haul the old one away, you will have to break the RV one loose, not a big deal.
Jim
Jim
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
