Almot
Jan 16, 2014Explorer III
az99 wrote:
Has anyone replaced this frig and what did you use as a residential replacement.
I have an 1800 PSW inverter and 4 batteries so I should be OK to run it.
Make sure the width fits. Many residential fridges over 6 cu.ft are at least 30" wide, too wide to fit into RV frig opening. Shut the propane vent on tank before removing the old fridge and cap the fridge propane line immediately.
1800W inverter? And what is the start-up current of your planned residential fridge?
4 batteries - what size? 4*225 AH @6V? With other electrical devices they will last 1 day before you have to charge them. In other words, daily music of a generator.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
