pianotuna
Apr 28, 2017Nomad III
Hi all,
I bypass the ARP protection device. The boiler temperature got to over 223 C (443 f). The ARP doesn't measure higher than that. By morning the freezer is at -18 c (-0.4 f) and the fridge is at about 4.5 c (40 f).
I'm going to install a bypass switch for the ARP, so that if this happens again I can eliminate it from the circuit.
I did use a sander (with no sand paper) to vibrate the fridge coils for over an hour. I did also use a hammer and a piece of wood to bang on the coils. But the fridge still went into over heat protection mode. Hence the desperation mode of bypassing the ARP.
Anyone have any idea of what happened?
Thank you all for your help.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
