- MrWizardModeratorMy fridge is labeled "Avanti" , like the car
And it is 7.5 CuFt, 90~~100w running
So that one would use about 1/2 the power while running
3.7 amps 12v just under 48w
If you shop around the Avant is under $300 - Chris_BryantExplorer IIDometic supposedly makes a DMC 2642 which is a 120/12 volt compressor model that is an exact replacement for the RM/DM2652/2662.
I say supposedly, as the only thing I have is a power point page and press release, other than that, I cannot find them. - MEXICOWANDERERExplorerMy Vestfrost eighteen cubic foot freezer unit consumes about 50 ampere hours a day. In 90F ambient and -5F contents temp. It uses a Danforth 24 volt compressor. 12 volt amp hours would be doubled.
But insulation and weight are massive. - CA_TravelerExplorer IIIFrom their website, but w/o cycle time, etc both figures could be correct.
Amps 120V/AC Amps 12-24V/DC
0.4 3.2-2.2 - pianotunaNomad IIIHi,
The online chat quoted me 5.8 amps @ 12 volts.
They don't do consumption testing. Goodness knows why.CA Traveler wrote:
But hard to say as the environment, efficiency and insulation are factors. - pianotunaNomad IIIHi Mr Wizard,
I think you may mean Sun Frost. None of them will fit (and Samsung says they don't make one that small).MrWizard wrote:
Wonder how it compares to a snow frost dc fridge - CA_TravelerExplorer IIIOK did find 3.2A @12V. Considering it's size that is consistent with the larger Samsungs which use 100-150Ah per day (inverter usage). But hard to say as the environment, efficiency and insulation are factors.
- CA_TravelerExplorer IIII had a similar unit 12V/120V in my boat and it used a 32V motor for the compressor. Used it for 20 years, always on w/o a problem.
I had no concerns about 12V power usage. I did check the manual of the posted unit and did not find any power usage, period. - pianotunaNomad IIIHi Mr Wizard,
I've asked for a quote.
IIRC you have a Samsung? Would it fit in my Class C (dimensions are in the link I sent).MrWizard wrote:
How much is that thing ?
Wonder how it compares to a snow frost dc fridge - SCVJeffExplorer
GordonThree wrote:
only those in Blue
Applications:
Portable restroom
Toddler training
Huh?
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
