dougrainer
Jan 13, 2020Nomad
Replace the Rear Control board. Remember the Thermister reading in diag mode is the FIN temp. The actual refer temp will be 10 degrees warmer. Also, a Defective Thermister will test(Ohm) out correctly. But, since you have replaced it, go with the control board. Are you positive the 4 wire quick connect by the interior light has good solid pin connections for the 2 wires to the Thermister? Doug
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 25, 2026
