dougrainer
Aug 31, 2019Nomad
kmb1966 wrote:Old-Biscuit wrote:
Dirty orifice'
Dirty burner
Dirty flue/flue baffle
Flue cap not in place
Low LP System Pressure
Thank you for these suggestions.
Since it is a new cooling unit, I am assuming that the flue/baffle and flue cap are all good. I know the flu cap is there (appears to be welded on the Amish unit).
I ordered a new burner and will install. I am not sure how to test the LP pressure
You are qualified to work at Camping World:B Your problem is LP PRESSURE! Replacing parts is NOT the fix. It is at CW. Doug
Having RV issues? Connect with others who have been in your shoes.24,366 PostsLatest Activity: Oct 05, 2023
