kmb1966
Sep 08, 2019Explorer
dougrainer wrote:kmb1966 wrote:Old-Biscuit wrote:
Dirty orifice'
Dirty burner
Dirty flue/flue baffle
Flue cap not in place
Low LP System Pressure
Thank you for these suggestions.
Since it is a new cooling unit, I am assuming that the flue/baffle and flue cap are all good. I know the flu cap is there (appears to be welded on the Amish unit).
I ordered a new burner and will install. I am not sure how to test the LP pressure
You are qualified to work at Camping World:B Your problem is LP PRESSURE! Replacing parts is NOT the fix. It is at CW. Doug
Update....
Doug is going to be right (again) on this. I changed the orifice and burner. Flame looks textbook correct. But still does not cool as well in propane mode as it does electric. 35 in electric, 42 in propane. (7 degree difference)
Having the LP pressure tested next.
Having RV issues? Connect with others who have been in your shoes.24,366 PostsLatest Activity: Oct 05, 2023
