A1RVTraveler
Jun 22, 2018Explorer
goldenhawk9 wrote:
Fridge won't turn on inside. Outside under panel there is a red light flashing on small black module. Has 4 wires. One says 12 V out.
The Norcold High Temperature Module has three different failure codes.
Solid Red Light - Lock out due to a high temperature sense issue.
Flashing Red Light - 1 flash per second - Low battery voltage sensed.
Flashing Red Light - 2 or 3 flashes Per second - High Limit Sensor (Brown Wires going to Flue) failure.
Might be time to find a trained professional.
