Old-Biscuit
Jun 19, 2018Explorer III
That RED light flashing is indicator the 'recall box' has shutdown ALL 12V DC power to fridge
*Either because it did its job.....trip DC and stop all heating functions due to High-High Temp being sensed via the thermal disc on boiler stack.....temp in excess of 700*F
*Tripped because module got WET
*Tripped because the module failed
Real issue is WHICH one caused the trip????
Do you see any 'yellowish residue' around/on burner area....remove shield and inspect
Do you smell any ammonia?
Did you recently wash RV..spray a little water into fridge area via vent cover?
What Revision number is module?
(Look at REV # via open area---latest was 'E')
You can reset the recall box using a strong magnet
Place it against face of box at top and slowly move back/forth ----should hear click and RED Light go OUT
Especially IF you were NOT operating fridge and found it tripped.
Otherwise could be due to overheating caused by cooling unit blockage.
imfreekinnuts
Jun 05, 2024Explorer
Thank you very much.
Thought lightning got us
