Chris_Bryant
Feb 06, 2020Explorer II
Those fuses failing is fairly common, the holder gets loose and/or corroded, and the ~300-450 watts continuos heats them up.
Checking fit and a bit of dielectric grease eliminates the problem.
The real tricky problem with the glass fuses is if they heat up the element can come unsoldered from the end cap- fuse looks good visually but doesn’t conduct.
Having RV issues? Connect with others who have been in your shoes.24,400 PostsLatest Activity: Jul 21, 2026
