kmb1966
Feb 06, 2020Explorer
enblethen wrote:
It is normal to have metal pipe grounded to stop any potential (or at least reduce the chance) arcing.
It could be a higher resistance then a good solid ground connection via a copper wire.
yes. I have it re-connected to the ground wire.
I was re-connecting everything when I noticed that if I connected the 12V before the ground wire, the propane igniter engaged and the burner lit. I now have the GND connector on the ground copper wire again.
Having RV issues? Connect with others who have been in your shoes.24,400 PostsLatest Activity: Jul 21, 2026
