kmb1966's avatar
kmb1966
Norcold 1200 operates without ground connected
I have been working on my Norcold 1200 again and have noticed that the unit will power up and operate when only connecting the 12 volt (+) supply to the rear control board connector labeled "12V". The connector labeled GND can be disconnected totally. Obviously there refrigerator is somehow already grounded somewhere, but I am wondering if this is a problem or is normal??
  • vermilye wrote:
    Do you have copper propane piping? One of my refrigerators ran on the hot & the propane copper pipe until the broken ground was discovered.
    ^^^^^^^ This ^^^^^^^
  • Do you have copper propane piping? One of my refrigerators ran on the hot & the propane copper pipe until the broken ground was discovered.
  • Is the refrigerator metal frame in any way touching the trailer metal frame? Trailer frame is ground, and the fridge internal 12 v ground may also be connected to the refrigerator frame.
  • It is possible that one of the screws holding the circuit board has a ground connection.
    The 120 volt element could be going to ground
  • wnjj wrote:
    It’s probably grounded through the 3rd pin of the AC power cord and I’m pretty sure it is normal.
    yes, but the only thing I noticed is that it will also operate when the 120 cord is unplugged making the refrigerator go to propane mode.
  • wnjj's avatar
    wnjj
    Explorer II
