ArchHoagland
Aug 17, 2017Explorer
dougrainer wrote:
Yes, IF the 2 wires are reversed the Cooling fans will not operate. VERY common mistake novices make. If all the tech did was r&r the Heating element, just reverse those 2 wires. I cannot remember which is which. I have that info at work. Doug
The Norcold manual has a picture of my control board showing the white lead on the left.
Mine has the black wire going to the left connection.
There is 5 volts DC on that connection.
Could you please check at work and determine if, indeed, the white wire should be on the left terminal.
Thanks.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
