dougrainer
Mar 06, 2020Nomad
kmb1966 wrote:BFL13 wrote:
I don't know if this is plausible, but---Is the thermistor losing its ground over that week where the light bulb snaps in? The light has the same ground at the other end of the light bulb holder. Maybe the light comes on and kickstarts that ground.
It appears to be something very close to what you are describing, but I cannot figure out what to do about it.
There are 4 wires. 2 for the Light assbly. 2 just for the Thermister. Both are separate from each other. Are you positive the Thermister is installed correctly on the Fin? Are your cooling fans operating? The White and Black wire bundle for the light and rear fans can be swapped by mistake on the rear control board. This will cause no obvious problems except the rear fans will not come on. Maybe it also causes your Thermister problem? The large white/small white goes on the LEFT terminal facing the control board. Doug
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
