dougrainer
Mar 07, 2020Nomad
1. Remove the Bulb from the light and see if the problem goes away
2. If not, then the odds are the rear Main board is bad
3. Long shot, would be corroded wire harness from the evap area thru the insulation of the box to the board. THIS is not a serviceable part.
4. How old is the refer?
5. Is the control board original? It is a Norcold board? Doug
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
