kmb1966
Mar 07, 2020Explorer
dougrainer wrote:
1. Remove the Bulb from the light and see if the problem goes away
2. If not, then the odds are the rear Main board is bad
3. Long shot, would be corroded wire harness from the evap area thru the insulation of the box to the board. THIS is not a serviceable part.
4. How old is the refer?
5. Is the control board original? It is a Norcold board? Doug
Thank you for the advice.
Will try removing the bulb and re-test.
The Norcold is a 2003, so it is old. On it's 3rd cooling unit (Amish)
Yes the board is a Norcold board.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
