Old-Biscuit
Jul 04, 2019Explorer III
Start with the basics (assuming you have a 6212XX Dino Bd)
DO you have 12VDC to fridge....display panel lights work/interior light turns on etc?
NO...check the Fuse that feds 12VDC to fridge terminal block (DC Dist Panel)
Fuse good/12VDC at terminal block then check the DC Fuse on circuit board (5A)
YES.....have 12VDC at fridge/DC Fuse good
AC needs 12VDC to function but uses a 5A Fast Acting fuse. (Some use 8A if they have 2 heater elements)
DO you have any error/fault codes?
Propane lights then goes out
Spark Electrode could be dirty/sooted so clean it using emery cloth/steel wool
Spark GAP 1/8' - 3/16' directly over center of burner slots so it is engulfed in flame when it lights off
Is burner slots free/clear of debris and fully intact (not rusted out/falling apart)?
What does flame look like when it does light.....strong/blue/reaching up into flue opening?
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
