Thank you for yor reply, I have talked to Dave at RV Cooling He is a great guy, I would go there if it wasnt so far away and have them re install it (Not him but the people that build it.) He and I have talked several times. I sent him all the picture's I had and what I have done.
I belive the Amish unit is a very good unit, I have to believe the rv shops just dont know or care when they put in a new unit, the RV Manager in Mission Tx. is a horses put toot. He does not like the amish cooling unit and they reinstalled it . And had another unit sent saying the first one was bad. I dont believe that.
I even called with the old serial number they took out seeing if they had checked it yet.
I paid $240. for new fans to be put on and they still didnt work, they crimped a wire wrong and didnt make the connection
Thats what Iron Horse in San Antonio found. We didn't know at the time there
was gaps in the fins and was not sealed right or I would had them take it out.
and try to fix it then. But we were on our way, before I realized it was heating up inside.
I tried running the gen set, I turn it off and taped the air vent on the back so air could not blow inside, (that worked the best)
I do believe that when they take these thing off if they are not careful they can really mess the back up and re-sealing them can go wrong.
I did call Iron Horse back after leaving, they said if it was torn up when taking the old unit off (twice) It might never be able to get seal right.
Im so frustrated Im think of put a house fridge in. Iron horse has been doing a lot of them, the owner himself has taken the norcold out of his RV and replaced it with a Samsung .
Being our age and not know if we will have this rv more that 3 yrs I don't know if spend $3000. to do a remake of a house fridge. is worth it, when sitting it works great.
