The fridge works well sitting still I have it set on 3-4 temp is 34-36inside and it is up to 90 degrees outside some times. it is going down the road when it heats up fast sucking hot air in when moving. No problems with lp it just cant keep up. no error codes. And it does defrost about every 48 hrs. now, before there was too much ice to get it all off when going threw a cycle.
I know i need it pulled and fixed, BUT I have spent over $1000. so far after it being fixed two times. extend warranty took care of most of it my delectable is $500. x2 plus the cost of new fans $240. I just want to try and see if we can get the hot air from quit coming in so bad going down the road. Iron Horse in San Antonio could do it, If when the unit was taken off (twice) and the back was not torn up to bad they might be able to reseal it. But the cost to find out and then not work, This would not be covered by warranty.
http://s1333.photobucket.com/user/lynneely/library/RV%20Fridge?sort=3&page=1
