Canadian_Rainbi
Aug 15, 2013Explorer
Canadian Rainbirds wrote:
Press the button, a click or two, hear flame start, 5 seconds or so later flame goes out and error message appears. Off for a long weekend of dry camping in the morning. Any suggestions would be appreciated. This in addition to the other 2 problems I posted about earlier. :h
Two good thoughts, and will try those ideas, but I should have mentioned in the beginning that other than the noise problem I mentioned in my previous thread, the fridge ran fine from Tuesday afternoon until late yesterday afternoon when I shut it down to move it to a sloped driveway to load up. It was when I moved it back up to the level spot last night to run the fridge again overnight that I found that it wouldn't stay lit this time.
Don; there is a nice little pile of rust under the burner but the burner itself is clear and burns with a nice even blue flame. When it goes out there is no warning flicker, it's like the valve was suddenly switched off. I'll vac it out anyway.
Now I'll fire up the generator and see if it will run on AC. Boondocking with a group through Sunday so I may have to run the generator more that I would like. The fridge draws too much on AC to use the inverter and the GCs for any length of time.
I'm out of here is an hour or so. Wish me luck!
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
