Old-Biscuit
Jul 06, 2014Explorer III
Fridge needs adequate air flow across cooling coil in order to cool and maintain temps.
That air flow is critical.
Sounds like insufficient air flow in bottom vent across coil and out top vent when in transit.
Might need to modify fan power by installing a manual On/Off switch so you can turn then on while in traveling vs them running on thermostat.
Fans ON while traveling MAY help correct air flow issue.
