hypoxia
Jul 18, 2014Explorer
pcm1959 wrote:dougrainer wrote:
The foil on the backside has absolutely NOTHING to do with sealing the cooling unit to the box. The foil just covers the cracks around the case. Doug
So you are saying that gaps and where sections on the back side meet that have gaps in them and where the foil has curled or lifted would not have anything to do with the heating-up during travel? Thanks, Phillip
Correct, it is sealed with foam & the tape just makes it look pretty.
Your leafblower test doesn't mean anything as the airflow is different going down the road. Ride in an open car; the wind comes from behind you which is why you see some with a screen behind the seats.
