pcm1959
Jul 18, 2014Explorer II
Fulltimer50 wrote:
Some of our models have, as mine did, a problem where the rubber gas line to the fridge bends shut when the slide is in. On mine they put in a longer line to give it more room to bend without crimping shut. Check it out.
Thanks for the tip. I don't think that this is the problem since the unit is running on lp with the slide in or out. It cools down to 34 degrees prior to travel but within 2 hours the refrig temp is up to 50 or higher. I'm not opening the doors as I have a wireless thermometer in the unit with the display in the truck. Phillip
