pcm1959
Jul 27, 2014Explorer II
dougrainer wrote:pcm1959 wrote:Fulltimer50 wrote:
Some of our models have, as mine did, a problem where the rubber gas line to the fridge bends shut when the slide is in. On mine they put in a longer line to give it more room to bend without crimping shut. Check it out.
Thanks for the tip. I don't think that this is the problem since the unit is running on lp with the slide in or out. It cools down to 34 degrees prior to travel but within 2 hours the refrig temp is up to 50 or higher. I'm not opening the doors as I have a wireless thermometer in the unit with the display in the truck. Phillip
Are you POSITIVE about the Evap drain pan hose not being open to the outside? There is supposed to be a check valve on the end of the drain hose. Some OEM's remove it and then run the drain out the bottom of the RV and THAT will allow hot air migration back up inside in transit. Doug
Plug is in end of drain tube and hangs in water collection bowl. Phillip
