I am assuming you had a 5th wheel when you reported poor or no cooling of your refrigerator while traveling. I have the same issue.
my 5th when loaded on my 2017 F350 rides 8” high at the nose. Did your 5th wheel ride high at the nose?
Considering this is issue 10 years ago, hopefully a solution was found :) however I have the same unit in my Class A Pusher, mine works well when driving, then heats up as parked. I tried all different insulation technics to get it sealed and still the same. Ventilation s the key, i assume, wish i can figure out the right set up
- charleshopperJul 01, 2025Explorer
Watch MyRvWorks in YouTube. He has an episode on proper baffling required for absorption refrigerators.
https://youtu.be/DxUnW7gudEE?si=fxviYLzdHV-CEfRZ- jetboatrich727Jul 02, 2025Explorer III
Good video thanks, i am sure that is my issue, my system is a little different with a roof vent
