Old-Biscuit
Dec 05, 2015Explorer III
Moving thermistor location on a fridge that has adjustable temp setting will NOT correct a cooling issue. It can affect food section temps by 4-6*F on a fridge that has NO adjustable temp settings.
Insufficient cooling on AC & LP on your 1210 Norcold is typically due to improper/lack of air flow (Draft)
Also can be due to one of the electric heaters has failed on AC
And low propane pressure on LP
But common to both is air flow. Check via upper vent cover for any obstruction
Blocked cooling unit!!!
Been running fridge with rig off-level :S
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
